メインコンテンツにスキップ
GuliKit KingKong 2 Pro Triggers Replacement
必要な工具と部品
  1. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the back cover screws: 手順 1、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: 手順 2、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: 手順 3、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: 手順 3、 2の画像 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. GuliKit KingKong 2 Pro Triggers Replacement: 手順 4、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement: 手順 4、 2の画像 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: 手順 5、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: 手順 5、 2の画像 2
    • Separate the back cover from the front assembly and remove it.
  6. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 3
    この手順で使用する道具:
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 3
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. GuliKit KingKong 2 Pro Triggers Replacement, Remove the vibration motors: 手順 8、 1の画像 1
    • Remove the vibration motors by lifting them out of the controller housing.
  9. GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: 手順 9、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: 手順 9、 2の画像 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 2
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the mainboard assembly screws: 手順 11、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: 手順 12、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: 手順 12、 2の画像 2
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: 手順 13、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: 手順 13、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: 手順 13、 3の画像 3
    • Remove the mainboard assembly by lifting it out of the controller housing.
  14. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the battery frame screw: 手順 14、 1の画像 1
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
  15. GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: 手順 15、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: 手順 15、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: 手順 15、 3の画像 3
    • Free the battery frame by lifting it off the plastic pins holding it in place.
  16. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: 手順 16、 2の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: 手順 16、 2の画像 2
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to disconnect the battery connector by pulling it straight out of its socket.
    • Remove the battery and its frame from the controller housing.
  17. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the trigger screws: 手順 17、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 7.8 mm-long screws securing the triggers.
  18. GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: 手順 18、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: 手順 18、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: 手順 18、 3の画像 3
    • Use your fingers to lift the left trigger off its bracket.
    • Remove the left trigger.
  19. GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: 手順 19、 3の画像 1 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: 手順 19、 3の画像 2 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: 手順 19、 3の画像 3
    • Repeat the previous procedure and lift the right trigger off its bracket to remove it.
終わりに
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
246,865 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,648のガイドは作成済み
10件のガイドコメント
Do you know where to buy a replacement zr trigger? The Black piece of Plastic,as in your last picture ,is broken on mine.
Strumpfmaskenmann - 返信
My Gulikit Kingkong 2 (non-pro) controller bought in Dec 2022 only uses PH01 screws. No PH00 ones. Otherwise this guide is very helpful for any disassembly you may want to do.
Sebastian Jost - 返信
When replacing the triggers, you need to recalibrate the controller before the new trigger(s) will work. I followed I followed the instructions found here for recalibrating when updating the firmware.
"Just press the four buttons of L,R,left of D-pad and A at the same time to quickly calibrate the sticks ZR,ZL with a vibration to solve this issue"
Captain Tinman - 返信
Did anyone find a retailer for a replacement trigger
Max Lang - 返信
Mate. You just show how to remove the triggers. How bout replacement ?????
John Robert Caleja - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 158
今までの合計 8,713
