メインコンテンツにスキップ
Google Pixel 9 Pro Fold Logic Board Replacement
必要な工具と部品
  1. Google Pixel 9 Pro Fold Logic Board Replacement, Prepare your phone for disassembly: 手順 1、 1の画像 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Logic Board Replacement, Insert an opening pick: 手順 2、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Insert an opening pick: 手順 2、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Logic Board Replacement, Separate the back cover adhesive: 手順 3、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Separate the back cover adhesive: 手順 3、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Separate the back cover adhesive: 手順 3、 3の画像 3
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 4、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 4、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 4、 3の画像 3
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 5、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 5、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 5、 3の画像 3
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 6、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 6、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 6、 3の画像 3
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the top bracket screw: 手順 7、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the top bracket screw: 手順 7、 2の画像 2
    この手順で使用する道具:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the top bracket: 手順 8、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the top bracket: 手順 8、 2の画像 2
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the back cover cable: 手順 9、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the back cover cable: 手順 9、 2の画像 2
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the back cover: 手順 10、 1の画像 1
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the base battery bracket screws: 手順 11、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the base battery bracket screws: 手順 11、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the base battery bracket: 手順 12、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the base battery bracket: 手順 12、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the base battery bracket: 手順 12、 3の画像 3
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the base battery: 手順 13、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the base battery: 手順 13、 2の画像 2
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the USB-C port board cable: 手順 14、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the USB-C port board cable: 手順 14、 2の画像 2
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the vibrator bracket screws: 手順 15、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the vibrator bracket screws: 手順 15、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the vibrator bracket: 手順 16、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the vibrator bracket: 手順 16、 2の画像 2
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the antenna cable: 手順 17、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the antenna cable: 手順 17、 2の画像 2
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera bracket screws: 手順 18、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera bracket screws: 手順 18、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera bracket: 手順 19、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera bracket: 手順 19、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera bracket: 手順 19、 3の画像 3
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the inner front camera: 手順 20、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the inner front camera: 手順 20、 2の画像 2
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera: 手順 21、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera: 手順 21、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner front camera: 手順 21、 3の画像 3
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold Logic Board Replacement, Separate the ultra wideband antenna: 手順 22、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Separate the ultra wideband antenna: 手順 22、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Separate the ultra wideband antenna: 手順 22、 3の画像 3
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the ultra wideband bracket screws: 手順 23、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the ultra wideband bracket screws: 手順 23、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the ultra wideband bracket: 手順 24、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the ultra wideband bracket: 手順 24、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the ultra wideband bracket: 手順 24、 3の画像 3
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the bottom interconnect cable bracket screw: 手順 25、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the bottom interconnect cable bracket screw: 手順 25、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the bottom interconnect cable bracket: 手順 26、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the bottom interconnect cable bracket: 手順 26、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the bottom interconnect cable bracket: 手順 26、 3の画像 3
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner display cable bracket screw: 手順 27、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner display cable bracket screw: 手順 27、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner display cable bracket: 手順 28、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the inner display cable bracket: 手順 28、 2の画像 2
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the inner display cable: 手順 29、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the inner display cable: 手順 29、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the inner display cable: 手順 29、 3の画像 3
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 30、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 30、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 30、 3の画像 3
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the graphite sheet: 手順 31、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the graphite sheet: 手順 31、 2の画像 2
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 32、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 32、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 32、 3の画像 3
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the side buttons: 手順 33、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Disconnect the side buttons: 手順 33、 2の画像 2
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 34、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 34、 2の画像 2
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 35、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 35、 2の画像 2
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold Logic Board Replacement, Separate the 5G mmWave antenna: 手順 36、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Separate the 5G mmWave antenna: 手順 36、 2の画像 2
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the logic board screws: 手順 37、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the logic board screws: 手順 37、 2の画像 2
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the logic board: 手順 38、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the logic board: 手順 38、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the logic board: 手順 38、 3の画像 3
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 39、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 39、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 39、 3の画像 3
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold Logic Board Replacement, Clean the thermal paste: 手順 40、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Clean the thermal paste: 手順 40、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Clean the thermal paste: 手順 40、 3の画像 3
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 41、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 41、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 41、 3の画像 3
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold Logic Board Replacement, End of disassembly: 手順 42、 1の画像 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  43. Google Pixel 9 Pro Fold Logic Board Replacement, Apply new thermal paste: 手順 43、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Apply new thermal paste: 手順 43、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Apply new thermal paste: 手順 43、 3の画像 3
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  44. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the logic board: 手順 44、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the logic board: 手順 44、 2の画像 2
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  45. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 45、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 45、 2の画像 2
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  46. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the side button cable: 手順 46、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the side button cable: 手順 46、 2の画像 2
    • Use angled tweezers to push the side button cable back into its slot.
  47. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 47、 1の画像 1
    • Flip the locking tab down and lightly press on it until it clicks into place.
  48. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 48、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 48、 2の画像 2
    • Place the yellow tape over the ZIF connector and its cable.
  49. Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new graphite sheet: 手順 49、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new graphite sheet: 手順 49、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new graphite sheet: 手順 49、 3の画像 3
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  50. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 50、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 50、 2の画像 2
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  51. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 51、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 51、 2の画像 2
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  52. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 52、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 52、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 52、 3の画像 3
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  53. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 53、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 53、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 53、 3の画像 3
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  54. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the right side cables: 手順 54、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the right side cables: 手順 54、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the right side cables: 手順 54、 3の画像 3
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  55. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner display cable bracket: 手順 55、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner display cable bracket: 手順 55、 2の画像 2
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  56. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 56、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 56、 2の画像 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  57. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the bottom interconnect cable bracket: 手順 57、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the bottom interconnect cable bracket: 手順 57、 2の画像 2
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  58. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 58、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 58、 2の画像 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  59. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the ultra wideband bracket: 手順 59、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the ultra wideband bracket: 手順 59、 2の画像 2
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  60. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 60、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 60、 2の画像 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  61. Google Pixel 9 Pro Fold Logic Board Replacement, Replace the ultra wideband bracket adhesive: 手順 61、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Replace the ultra wideband bracket adhesive: 手順 61、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Replace the ultra wideband bracket adhesive: 手順 61、 3の画像 3
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  62. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the old adhesive: 手順 62、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the old adhesive: 手順 62、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the old adhesive: 手順 62、 3の画像 3
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  63. Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 63、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 63、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 63、 3の画像 3
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  64. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 64、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 64、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 64、 3の画像 3
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  65. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 65、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 65、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 65、 3の画像 3
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  66. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner front camera: 手順 66、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner front camera: 手順 66、 2の画像 2
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  67. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner front camera bracket: 手順 67、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner front camera bracket: 手順 67、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the inner front camera bracket: 手順 67、 3の画像 3
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  68. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 68、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 68、 2の画像 2
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  69. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the antenna cable: 手順 69、 1の画像 1
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  70. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the vibrator bracket: 手順 70、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the vibrator bracket: 手順 70、 2の画像 2
    • Place the vibrator bracket on the logic board and align its screw holes.
  71. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 71、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 71、 2の画像 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  72. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the USB-C port board cable: 手順 72、 1の画像 1
    • Reconnect the USB-C port board cable press connector.
  73. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the base battery: 手順 73、 1の画像 1
    • Reconnect the base battery press connector.
  74. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the base battery bracket: 手順 74、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the base battery bracket: 手順 74、 2の画像 2
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  75. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 75、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 75、 2の画像 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  76. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the old adhesive: 手順 76、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the old adhesive: 手順 76、 2の画像 2
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  77. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the back cover liners: 手順 77、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the back cover liners: 手順 77、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the back cover liners: 手順 77、 3の画像 3
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  78. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 78、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 78、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 78、 3の画像 3
    • Peel off the remaining clear liners on the outside of the back cover.
  79. Google Pixel 9 Pro Fold Logic Board Replacement, Compare your adhesive: 手順 79、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Compare your adhesive: 手順 79、 2の画像 2
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  80. Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 80、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 80、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement, Apply the new adhesive: 手順 80、 3の画像 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  81. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 81、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 81、 2の画像 2
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  82. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 82、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 82、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 82、 3の画像 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  83. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 83、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 83、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 83、 3の画像 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  84. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 84、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 84、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 84、 3の画像 3
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  85. Google Pixel 9 Pro Fold Logic Board Replacement, Reconnect the back cover cable: 手順 85、 1の画像 1
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  86. Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the top bracket: 手順 86、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Reinstall the top bracket: 手順 86、 2の画像 2
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  87. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 87、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 87、 2の画像 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  88. Google Pixel 9 Pro Fold Logic Board Replacement, Remove the secondary liner: 手順 88、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Remove the secondary liner: 手順 88、 2の画像 2
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  89. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 89、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 89、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 89、 3の画像 3
    • Peel off the secondary liner to expose the adhesive.
  90. Google Pixel 9 Pro Fold Logic Board Replacement, Secure the back cover: 手順 90、 2の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement, Secure the back cover: 手順 90、 2の画像 2
    • Align the top edge of the back cover with the frame and press down to adhere it.
  91. Google Pixel 9 Pro Fold Logic Board Replacement: 手順 91、 3の画像 1 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 91、 3の画像 2 Google Pixel 9 Pro Fold Logic Board Replacement: 手順 91、 3の画像 3
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
終わりに
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
ある他の人がこのガイドを完成しました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,038 ポイント
1,040のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,623のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 84
今までの合計 872
