メインコンテンツにスキップ
Garmin StreetPilot c330 Battery Replacement
必要な工具と部品
  1. Garmin StreetPilot c330 Battery Replacement, Outer Casing: 手順 1、 3の画像 1 Garmin StreetPilot c330 Battery Replacement, Outer Casing: 手順 1、 3の画像 2 Garmin StreetPilot c330 Battery Replacement, Outer Casing: 手順 1、 3の画像 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Battery Replacement: 手順 2、 3の画像 1 Garmin StreetPilot c330 Battery Replacement: 手順 2、 3の画像 2 Garmin StreetPilot c330 Battery Replacement: 手順 2、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Battery Replacement: 手順 3、 2の画像 1 Garmin StreetPilot c330 Battery Replacement: 手順 3、 2の画像 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Battery Replacement: 手順 4、 3の画像 1 Garmin StreetPilot c330 Battery Replacement: 手順 4、 3の画像 2 Garmin StreetPilot c330 Battery Replacement: 手順 4、 3の画像 3
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Battery Replacement: 手順 5、 1の画像 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Battery Replacement, Battery: 手順 6、 3の画像 1 Garmin StreetPilot c330 Battery Replacement, Battery: 手順 6、 3の画像 2 Garmin StreetPilot c330 Battery Replacement, Battery: 手順 6、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Battery Replacement: 手順 7、 3の画像 1 Garmin StreetPilot c330 Battery Replacement: 手順 7、 3の画像 2 Garmin StreetPilot c330 Battery Replacement: 手順 7、 3の画像 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
終わりに
ある他の人がこのガイドを完成しました。
作成者
15人の作成者と共同で作成されました。
Adrian Leon
メンバー登録日: 10/07/10
173 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 15
今までの合計 4,584
