はじめに
Follow the instructions in this guide to replace the RGB lights in your GameSir Cyclone 2 controller.
必要な工具と部品
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
ある他の人がこのガイドを完成しました。
