はじめに
The motherboard connects everything in the camera together. A working Motherboard is essential for the camera to function properly as a complete unit.
必要な工具と部品
Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
Unlatch the four clasps located on each side of the camera by hand.
The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm FinePix XP50 Battery Replacement for instructions.
Using Phillips #00 screwdriver, remove four 3.0 mm screws holding motherboard in place.
There are four wires that are soldered to the motherboard. Detach these wires from the motherboard by desoldering them.This will free the motherboard.
For instructions on desoldering see はんだ付けとはんだ除去の作業ガイド
2 の人々がこのガイドを完成させました。
