メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Flydigi Apex 4 Trigger Assembly Replacement
必要な工具と部品
  1. Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 1 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 2 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 手順 1、 3の画像 3
    • Ensure the controller is fully powered off before beginning.
    • Disconnect the USB-C cable if the controller is plugged in.
    • Remove any wireless adapter or dongle connected to your device.
    • Never work on the controller while it is powered on or charging. Doing so may damage internal components or cause injury.
    FixBotに聞いてみる
    コメントを追加
  2. Flydigi Apex 4 Trigger Assembly Replacement: 手順 2、 3の画像 1 Flydigi Apex 4 Trigger Assembly Replacement: 手順 2、 3の画像 2 Flydigi Apex 4 Trigger Assembly Replacement: 手順 2、 3の画像 3
    • Remove the button caps and the magnetic faceplate of the controller.
    • It should come off with a tug.
    • Use a Phillips #00 screwdriver to remove the four screws securing the front of the controller to the frame.
    • Some screws may be hidden under grip pads or stickers. Gently peel these back if necessary.
    FixBotに聞いてみる
    コメントを追加
  3. Flydigi Apex 4 Trigger Assembly Replacement: 手順 3、 2の画像 1 Flydigi Apex 4 Trigger Assembly Replacement: 手順 3、 2の画像 2
    • Insert a plastic opening tool into the seam between the front and back shell along the bottom edge of the controller.
    • Gently run the opening tool along the seam to release the plastic clips holding the two halves together.
    • Work your way around all edges until the back shell is fully unclipped.
    • Carefully lift the back shell away from the front half and set it aside.
    • Do not force the shell open. If you feel strong resistance, check for any screws you may have missed.
    FixBotに聞いてみる
    コメントを追加
  4. Flydigi Apex 4 Trigger Assembly Replacement: 手順 4、 1の画像 1
    • With the controller open, identify the trigger assembly on the side you are replacing.
    • The trigger assembly consists of the trigger lever, the spring mechanism, and the analog sensor attached to the internal frame.
    • Take a photo of the internal layout before removing any components. This will help you reassemble the controller correctly.
    FixBotに聞いてみる
    コメントを追加
  5. Flydigi Apex 4 Trigger Assembly Replacement: 手順 5、 3の画像 1 Flydigi Apex 4 Trigger Assembly Replacement: 手順 5、 3の画像 2 Flydigi Apex 4 Trigger Assembly Replacement: 手順 5、 3の画像 3
    • Use a spudger or your fingernail to gently flip up the locking tab on the connector linking the trigger assembly to the main PCB.
    • Carefully pull the ribbon cable straight out of the connector.
    • Do not pull at an angle, as this may tear the cable.
    FixBotに聞いてみる
    コメントを追加
  6. Flydigi Apex 4 Trigger Assembly Replacement: 手順 6、 2の画像 1 Flydigi Apex 4 Trigger Assembly Replacement: 手順 6、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the screws securing each trigger assembly.
    • Lift the trigger assembly straight up and out of the controller frame.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
janavi
メンバー登録日: 03/23/25
241 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-1, Shaddix Spring 2026 UMass Dartmouth, Team 3-1, Shaddix Spring 2026人のメンバー
UMASSD-SHADDIX-S26S3G1
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 31
過去 30 日: 111
今までの合計 181
