メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fix unstable bluetooth connection
必要な工具と部品
    1. Fix unstable bluetooth connection, Heating up the lid: 手順 1、 1の画像 1
      • Heat up the lid by leaving the earbud upside down on a hotplate at ~80°C for ~1min. A 3d printers hotbed works well for this.
      • A heat gun should also work as well.
      FixBotに聞いてみる
      コメントを追加
    2. Fix unstable bluetooth connection, Breaking the seal: 手順 2、 1の画像 1
      • The earbuds are glued shut.
      • Put some cloth around the earbud and put it in a vice like shown.
      • Pliers might work too if you don't have a vice but it's not recommended.
      • Slowly close the vice until there is a cracking sound or a gap forms in the seam.
      FixBotに聞いてみる
      コメントを追加
    3. Fix unstable bluetooth connection, Removing the lid: 手順 3、 1の画像 1
      • Heat up the lid again before continuing.
      • Separate the 2 halfs using one of the opening picks.
      • Make sure not to press the pick more then ~1mm into the case to avoid damaging anything on the PCB.
      • Slowly lift up the outer half after cracking the seal around the whole earbud. Slowly pull them apart as there is some flexible adhesive on 2 internal pegs that takes a bit of time to "give up".
      FixBotに聞いてみる
      コメントを追加
    4. Fix unstable bluetooth connection, Secure the mic cover: 手順 4、 1の画像 1
      • The marked mic cover tends to easily get lost. It's best to take it of and store it with the top half until reassembly.
      FixBotに聞いてみる
      コメントを追加
    5. Fix unstable bluetooth connection, Scrape away old glue: 手順 5、 1の画像 1
      • Try to remove as much of the hard, clear glue on the outside edge to make sure the buds close nicely when reassembling them.
      • A precision rotary tool with a fine abrasive tip and/or a scalpel works best.
      FixBotに聞いてみる
      コメントを追加
    6. Fix unstable bluetooth connection, Remove old glue: 手順 6、 1の画像 1
      • Try to remove as much of the white glue as possible using a scalpel and/or tweezers.
      • Putting the lid back on the hotplate or a bit of Isopropanol can help softening it.
      FixBotに聞いてみる
      コメントを追加
    7. FixBotに聞いてみる
      コメントを追加
    1. Fix unstable bluetooth connection, Lift antenna: 手順 8、 2の画像 1 Fix unstable bluetooth connection, Lift antenna: 手順 8、 2の画像 2
      • Lift up the contact area of the antenna with a scalpel.
      • Be especially careful when pushing it around the mic port(marked in red) that's beneath it.
      FixBotに聞いてみる
      コメントを追加
    2. Fix unstable bluetooth connection, Add piece of foam: 手順 9、 1の画像 1
      • Put a thin piece of foam the size of the contact area behind it.
      FixBotに聞いてみる
      コメントを追加
    3. Fix unstable bluetooth connection, Push the antenna back in place: 手順 10、 1の画像 1
      • Fold the contact are back down.
      FixBotに聞いてみる
      コメントを追加
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Byte Hoarder
メンバー登録日: 07/03/25
535 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 409
