メインコンテンツにスキップ
Fitbit Ionic Display Assembly Replacement
必要な工具と部品
  1. Fitbit Ionic Display Assembly Replacement, How to open the Fitbit Ionic: 手順 1、 2の画像 1 Fitbit Ionic Display Assembly Replacement, How to open the Fitbit Ionic: 手順 1、 2の画像 2
    • Before starting, take your Fitbit Ionic off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Fitbit Ionic Display Assembly Replacement: 手順 2、 1の画像 1
    • Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
    • The adhesive of the Fitbit Ionic is very strong. You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  3. Fitbit Ionic Display Assembly Replacement: 手順 3、 3の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 3、 3の画像 2 Fitbit Ionic Display Assembly Replacement: 手順 3、 3の画像 3
    • Insert a technician's razor with a flat blade into the small gap between the watch case and the display.
    • Cut through the adhesive on the upper side of the Fitbit Ionic.
  4. Fitbit Ionic Display Assembly Replacement: 手順 4、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 4、 2の画像 2
    • Use a technician's razor with a flat blade to pry up the top edge of the display and create a small gap.
  5. Fitbit Ionic Display Assembly Replacement: 手順 5、 3の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 5、 3の画像 2 Fitbit Ionic Display Assembly Replacement: 手順 5、 3の画像 3
    • Insert two opening picks underneath the top left and the top right corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Remove the razor blade.
  6. Fitbit Ionic Display Assembly Replacement: 手順 6、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 6、 2の画像 2
    • Insert a third opening pick underneath the top right corner and slide it along the right edge of the display.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  7. Fitbit Ionic Display Assembly Replacement: 手順 7、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 7、 2の画像 2
    • Insert a fourth opening pick underneath the top left corner and slide it along the left edge of the display.
    • Leave the opening pick in bottom left corner to prevent the adhesive from resealing.
    • Do not remove the display assembly all the way yet—it's still connected to the mainboard.
  8. Fitbit Ionic Display Assembly Replacement: 手順 8、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 8、 2の画像 2
    • Carefully fold the display assembly in the direction of the bottom edge.
  9. Fitbit Ionic Display Assembly Replacement, Display Assembly: 手順 9、 2の画像 1 Fitbit Ionic Display Assembly Replacement, Display Assembly: 手順 9、 2の画像 2
    • Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna.
    • Carefully fold the NFC antenna in the direction of the upper edge of the watch.
  10. Fitbit Ionic Display Assembly Replacement: 手順 10、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 10、 2の画像 2
    • Carefully fold the display assembly onto the upper side of the watch.
    • Take care not to pull or bend the cables too much—they are still connected to the mainboard.
  11. Fitbit Ionic Display Assembly Replacement: 手順 11、 1の画像 1
    • Remove the Torx T2 screw (3.65 mm length) on the bottom left corner.
  12. Fitbit Ionic Display Assembly Replacement: 手順 12、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to remove the metal shield covering the battery flex cable.
  13. Fitbit Ionic Display Assembly Replacement: 手順 13、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  14. Fitbit Ionic Display Assembly Replacement: 手順 14、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 14、 2の画像 2
    • Fold the display assembly back to its original position.
  15. Fitbit Ionic Display Assembly Replacement: 手順 15、 1の画像 1
    • Remove the two Torx T2 screws (3.65 mm length) from the top edge of the watch.
  16. Fitbit Ionic Display Assembly Replacement: 手順 16、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 16、 2の画像 2
    • Use a pair of tweezers to remove the metal cover.
  17. Fitbit Ionic Display Assembly Replacement: 手順 17、 2の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 17、 2の画像 2
    • Use a spudger to pry up and disconnect the NFC antenna.
    • Remove the NFC antenna.
  18. Fitbit Ionic Display Assembly Replacement: 手順 18、 3の画像 1 Fitbit Ionic Display Assembly Replacement: 手順 18、 3の画像 2 Fitbit Ionic Display Assembly Replacement: 手順 18、 3の画像 3
    • Use a spudger to pry up and disconnect the two display cables from the motherboard.
  19. Fitbit Ionic Display Assembly Replacement: 手順 19、 1の画像 1
    • Remove the display assembly.
    • If possible, turn on your Fitbit Ionic and test your repair before installing new adhesive and resealing.
終わりに
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
61,986 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,638のガイドは作成済み
2件のガイドコメント
It says in the description that you need replacement adhesive when reassembling, but what adhesive do you mean? Adhesive strips, adhesive glue? In all my searching nobody seems to have a good answer. The best thing I could find was b-7000 glue on amazon, but some people say it is water proof some say it Isn’t waterproof, so I’m not sure what to do. Any advice/feedback would be much appreciated!
JJB - 返信
Hi JJB, it’s very difficult to seal your watch waterproof after a repair but I can recommend this glue. I hope your repair works! Feel free to share your experience with us when you have finished it.
Adriana Zwink -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 6,247
