メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Epson PowerLite 77c Fan Replacement
必要な工具と部品
  1. Epson PowerLite 77c Fan Replacement, Lamp: 手順 1、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
    FixBotに聞いてみる
    コメントを追加
  2. Epson PowerLite 77c Fan Replacement: 手順 2、 1の画像 1
    • Slide the cover toward you, then lift it to remove it.
    FixBotに聞いてみる
    コメントを追加
  3. Epson PowerLite 77c Fan Replacement: 手順 3、 2の画像 1 Epson PowerLite 77c Fan Replacement: 手順 3、 2の画像 2
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
    FixBotに聞いてみる
    コメントを追加
  4. Epson PowerLite 77c Fan Replacement, Fan: 手順 4、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
    FixBotに聞いてみる
    コメントを追加
  5. Epson PowerLite 77c Fan Replacement: 手順 5、 2の画像 1 Epson PowerLite 77c Fan Replacement: 手順 5、 2の画像 2
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
    FixBotに聞いてみる
    コメントを追加
  6. Epson PowerLite 77c Fan Replacement: 手順 6、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
    FixBotに聞いてみる
    コメントを追加
  7. Epson PowerLite 77c Fan Replacement: 手順 7、 2の画像 1 Epson PowerLite 77c Fan Replacement: 手順 7、 2の画像 2
    • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
    • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  8. Epson PowerLite 77c Fan Replacement: 手順 8、 1の画像 1
    • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. Epson PowerLite 77c Fan Replacement: 手順 9、 2の画像 1 Epson PowerLite 77c Fan Replacement: 手順 9、 2の画像 2
    • Grip the fan and lift it up and out.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Xandher Thao
メンバー登録日: 02/08/22
161 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team 1-6, Virtue Spring 2022 Western Carolina University, Team 1-6, Virtue Spring 2022人のメンバー
WCU-VIRTUE-S22S1G6
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 16
今までの合計 377
