メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
必要な工具と部品
    1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: 手順 1、 2の画像 1 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: 手順 1、 2の画像 2
      • Plastic spudgers/opening tools
      • T2 Torx Screwdriver
      FixBotに聞いてみる
      コメントを追加
    2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: 手順 2、 1の画像 1
      • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
      • Replacement batteries are two (2) CR 2032 coin cell batteries.
      FixBotに聞いてみる
      コメントを追加
    3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: 手順 3、 2の画像 1 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: 手順 3、 2の画像 2
      • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
      • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
      • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
      FixBotに聞いてみる
      コメントを追加
    4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: 手順 4、 2の画像 1 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: 手順 4、 2の画像 2
      • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
      • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
      FixBotに聞いてみる
      コメントを追加
    5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: 手順 5、 2の画像 1 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: 手順 5、 2の画像 2
      • The remote should now be fully disassembled.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Skeven
メンバー登録日: 04/21/25
152 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 56
今までの合計 540
