メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DigiLand DL1010Q Battery Replacement
必要な工具と部品
  1. DigiLand DL1010Q Battery Replacement, Rear Case: 手順 1、 1の画像 1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
    FixBotに聞いてみる
    コメントを追加
  2. DigiLand DL1010Q Battery Replacement: 手順 2、 2の画像 1 DigiLand DL1010Q Battery Replacement: 手順 2、 2の画像 2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    FixBotに聞いてみる
    コメントを追加
  3. DigiLand DL1010Q Battery Replacement: 手順 3、 1の画像 1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
    FixBotに聞いてみる
    コメントを追加
  4. DigiLand DL1010Q Battery Replacement, Battery: 手順 4、 2の画像 1 DigiLand DL1010Q Battery Replacement, Battery: 手順 4、 2の画像 2
    • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
    • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
    FixBotに聞いてみる
    コメントを追加
  5. DigiLand DL1010Q Battery Replacement: 手順 5、 2の画像 1 DigiLand DL1010Q Battery Replacement: 手順 5、 2の画像 2
    • Using a metal spudger tool, wedge between battery and metal screen.
    • Follow the edge of the battery to loosen the glue.
    FixBotに聞いてみる
    コメントを追加
  6. DigiLand DL1010Q Battery Replacement: 手順 6、 2の画像 1 DigiLand DL1010Q Battery Replacement: 手順 6、 2の画像 2
    • Once the glue is loosened, you should be able to pry off the battery from the screen.
    • Using your hands, pull up on the battery to pull battery off.
    • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    • The battery will be completely disconnected and you can set the battery aside in a safe place.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Faith Lebo
メンバー登録日: 09/28/15
212 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-5, Matresse Fall 2015 Eastern Washington University, Team 1-5, Matresse Fall 2015人のメンバー
EWU-MATRESSE-F15S1G5
4 メンバー
13のガイドは作成済み
3件のガイドコメント
the replacemet has 3 wires .where go the 3 wire?
javier perez - 返信 共有
were can i buy a new  bettery
Theresa - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 35
今までの合計 4,999
