メインコンテンツにスキップ
Dell XPS 17 9710 Battery Replacement
必要な工具と部品
  1. Dell XPS 17 9710 Battery Replacement, Prepare your device: 手順 1、 1の画像 1
    • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
    • Power off and unplug your laptop.
    • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
  2. Dell XPS 17 9710 Battery Replacement, Remove the lower case screws: 手順 2、 1の画像 1
    • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
    • The lower case is further secured by various clips that must be released before removal.
  3. Dell XPS 17 9710 Battery Replacement, Begin to release the clips: 手順 3、 3の画像 1 Dell XPS 17 9710 Battery Replacement, Begin to release the clips: 手順 3、 3の画像 2 Dell XPS 17 9710 Battery Replacement, Begin to release the clips: 手順 3、 3の画像 3
    • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
    • Insert the flat end of a spudger into the gap created by the opening pick.
    • Pivot the spudger up to release the first set of retaining clips.
    • Repeat this process for the bottom right corner.
  4. Dell XPS 17 9710 Battery Replacement, Release the remaining clips: 手順 4、 3の画像 1 Dell XPS 17 9710 Battery Replacement, Release the remaining clips: 手順 4、 3の画像 2 Dell XPS 17 9710 Battery Replacement, Release the remaining clips: 手順 4、 3の画像 3
    • Insert an opening pick into the gap created on the front edge of the laptop.
    • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
  5. Dell XPS 17 9710 Battery Replacement, Remove the lower case: 手順 5、 3の画像 1 Dell XPS 17 9710 Battery Replacement, Remove the lower case: 手順 5、 3の画像 2 Dell XPS 17 9710 Battery Replacement, Remove the lower case: 手順 5、 3の画像 3
    • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
    • Lift the lower case up and off of the chassis to remove it.
  6. 注意: 手順 6 は、作業進行中としてマークされている ガイド から引用されています。
    Dell XPS 17 9710 Battery Replacement, Dell XPS 17 9710 Battery Disconnection: 手順 6、 3の画像 1 Dell XPS 17 9710 Battery Replacement, Dell XPS 17 9710 Battery Disconnection: 手順 6、 3の画像 2 Dell XPS 17 9710 Battery Replacement, Dell XPS 17 9710 Battery Disconnection: 手順 6、 3の画像 3
    • Use the flat end of a spudger to pry the battery's connector up, directly out of its socket.
    • Alternatively, grip the battery connector pull tab with your fingers and lift straight up to disconnect it.
    • During reassembly, line the connector up with the socket and push down gently with a finger to reconnect it.
    • The connector should seat in place with minimal resistance. If it feels difficult to reconnect, realign the connector and try again.
  7. Dell XPS 17 9710 Battery Replacement, Battery: 手順 7、 1の画像 1
    • Remove the seven 4.1 mm-long Phillips screws that secure the battery.
  8. Dell XPS 17 9710 Battery Replacement, Remove the battery: 手順 8、 3の画像 1 Dell XPS 17 9710 Battery Replacement, Remove the battery: 手順 8、 3の画像 2 Dell XPS 17 9710 Battery Replacement, Remove the battery: 手順 8、 3の画像 3
    • Use the flat end of a spudger to lift the front edge of the battery until you can easily grip it with your fingers.
    • Whenever you use a spudger or other sharp tools near the battery, be very careful not to accidentally poke or puncture it.
    • Lift the battery up and out of its recess to remove it.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Connor Bassolino
メンバー登録日: 03/29/22
6,570 ポイント
28のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,269のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 30
今までの合計 235
