はじめに
This guide will show you how to replace the battery in a Dell Latitude E5450.
If your battery is swollen, take appropriate precautions.
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the six Philips #0 screws from the lower case.
Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
Pry up to release the two central clips along the upper edge of the case.
Pull up on the battery connector's pull tab to disconnect the battery.
Remove the three 5.6 mm Philips #0 screws from the top edge of the battery.
For optimal performance, calibrate your newly-installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Dell Latitude Answers community for troubleshooting help.
5 件のコメント
im in need of dell latitude e5450 motherboard,
Hi I got my first battery to replace my old one and when I had unboxed it and installed it it didn't turn on so I looked at the back and saw that the back had these 4 squares with there light blue patches cover them and idk if should take them off cause they seem peelable but idk of I should peel them off
Hi! Please contact our customer support and we will get the issue resolved!
i got error code 2000-0132 after replace the battery
Is a battery type RYXXH compatible with the laptop Dell e5450? even though RYXXH is 11.1 V and the one that it had is 7 V.
