メインコンテンツにスキップ
Dell Latitude 7490 Battery Replacement
必要な工具と部品
  1. Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Dell Latitude 7490 Battery Replacement, Flip your laptop over: 手順 2、 1の画像 1
    • Flip your laptop over so the rubber feet strips are facing up.
  3. Dell Latitude 7490 Battery Replacement, Loosen the captive screws: 手順 3、 2の画像 1 Dell Latitude 7490 Battery Replacement, Loosen the captive screws: 手順 3、 2の画像 2
    • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
  4. Dell Latitude 7490 Battery Replacement, Insert an opening pick: 手順 4、 3の画像 1 Dell Latitude 7490 Battery Replacement, Insert an opening pick: 手順 4、 3の画像 2 Dell Latitude 7490 Battery Replacement, Insert an opening pick: 手順 4、 3の画像 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Insert the long side of an opening pick between the top right corner of the back cover and frame.
    • Pry the back cover up to release the clips securing the top right corner.
  5. Dell Latitude 7490 Battery Replacement, Release the clips: 手順 5、 3の画像 1 Dell Latitude 7490 Battery Replacement, Release the clips: 手順 5、 3の画像 2 Dell Latitude 7490 Battery Replacement, Release the clips: 手順 5、 3の画像 3
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Dell Latitude 7490 Battery Replacement: 手順 6、 3の画像 1 Dell Latitude 7490 Battery Replacement: 手順 6、 3の画像 2 Dell Latitude 7490 Battery Replacement: 手順 6、 3の画像 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Dell Latitude 7490 Battery Replacement, Remove the back cover: 手順 7、 3の画像 1 Dell Latitude 7490 Battery Replacement, Remove the back cover: 手順 7、 3の画像 2 Dell Latitude 7490 Battery Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
  8. Dell Latitude 7490 Battery Replacement, Disconnect the battery: 手順 8、 2の画像 1 Dell Latitude 7490 Battery Replacement, Disconnect the battery: 手順 8、 2の画像 2
    • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
    • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
  9. Dell Latitude 7490 Battery Replacement, Unfasten the battery: 手順 9、 2の画像 1 Dell Latitude 7490 Battery Replacement, Unfasten the battery: 手順 9、 2の画像 2
    • Use a Phillips screwdriver to remove the two 5.7 mm‑long screws securing the battery.
  10. Dell Latitude 7490 Battery Replacement, Remove the battery: 手順 10、 3の画像 1 Dell Latitude 7490 Battery Replacement, Remove the battery: 手順 10、 3の画像 2 Dell Latitude 7490 Battery Replacement, Remove the battery: 手順 10、 3の画像 3
    • Lift the top edge of the battery.
    • Slide the battery's bottom edge out of its recess in the frame and remove the battery.
  11. Dell Latitude 7490 Battery Replacement, Reassembly information: 手順 11、 3の画像 1 Dell Latitude 7490 Battery Replacement, Reassembly information: 手順 11、 3の画像 2 Dell Latitude 7490 Battery Replacement, Reassembly information: 手順 11、 3の画像 3
    • During reassembly, slide the four plastic tabs on the bottom edge of the battery into their recesses on the frame before securing the battery.
  12. Dell Latitude 7490 Battery Replacement, Remove the battery cable: 手順 12、 3の画像 1 Dell Latitude 7490 Battery Replacement, Remove the battery cable: 手順 12、 3の画像 2 Dell Latitude 7490 Battery Replacement, Remove the battery cable: 手順 12、 3の画像 3
    • If your replacement battery doesn’t come with a cable preinstalled, you’ll have to transfer your original cable to the new battery.
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Flip the battery over and lay it on a clean working surface.
    • Use one hand to secure the battery.
    • Use your other hand to firmly pull the battery connector out of its socket on the bottom edge of the battery.
    • Remove the battery cable from its recess between the two battery cells.
    • During reassembly, transfer the battery cable to your new battery, making sure the cable is snug between the battery cells.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
メンバー登録日: 09/14/22
53,748 ポイント
394のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,199のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 64
過去 30 日: 333
今までの合計 2,218
