メインコンテンツにスキップ
Dell Inspiron 11-3162 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 11-3162 Battery Replacement, Back Cover Removal: 手順 1、 2の画像 1 Dell Inspiron 11-3162 Battery Replacement, Back Cover Removal: 手順 1、 2の画像 2
    この手順で使用する道具:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 11-3162 Battery Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Battery Replacement: 手順 3、 1の画像 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Battery Replacement: 手順 4、 3の画像 1 Dell Inspiron 11-3162 Battery Replacement: 手順 4、 3の画像 2 Dell Inspiron 11-3162 Battery Replacement: 手順 4、 3の画像 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Battery Replacement, Battery: 手順 5、 2の画像 1 Dell Inspiron 11-3162 Battery Replacement, Battery: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Battery Replacement: 手順 6、 3の画像 1 Dell Inspiron 11-3162 Battery Replacement: 手順 6、 3の画像 2 Dell Inspiron 11-3162 Battery Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Dominic DeLong
メンバー登録日: 09/29/16
775 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 1-2, Crane Fall 2016 Eastern Washington University, Team 1-2, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G2
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 34
今までの合計 3,363
