メインコンテンツにスキップ
Dell G15-5510 Gaming Battery Replacement
必要な工具と部品
  1. Dell G15-5510 Gaming Battery Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Dell G15-5510 Gaming Battery Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
    • Two 8 mm screws
    • Two 5.8 mm screws
    • Loosen the four captive screws.
  2. Dell G15-5510 Gaming Battery Replacement, Unclip the front corners: 手順 2、 2の画像 1 Dell G15-5510 Gaming Battery Replacement, Unclip the front corners: 手順 2、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry upward to release clips holding the cover in place.
    • Listen for a loud click to indicate a clip being released.
  3. Dell G15-5510 Gaming Battery Replacement: 手順 3、 2の画像 1 Dell G15-5510 Gaming Battery Replacement: 手順 3、 2の画像 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5510 Gaming Battery Replacement, Remove the back cover: 手順 4、 3の画像 1 Dell G15-5510 Gaming Battery Replacement, Remove the back cover: 手順 4、 3の画像 2 Dell G15-5510 Gaming Battery Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: 手順 5、 3の画像 1 Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: 手順 5、 3の画像 2 Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: 手順 5、 3の画像 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5510 Gaming Battery Replacement, Unfasten the battery: 手順 6、 2の画像 1 Dell G15-5510 Gaming Battery Replacement, Unfasten the battery: 手順 6、 2の画像 2
    • Use a Phillips screwdriver to remove the four 4.1 mm-long screws securing the battery.
  7. Dell G15-5510 Gaming Battery Replacement, Remove the battery: 手順 7、 3の画像 1 Dell G15-5510 Gaming Battery Replacement, Remove the battery: 手順 7、 3の画像 2 Dell G15-5510 Gaming Battery Replacement, Remove the battery: 手順 7、 3の画像 3
    • Pull the battery towards the top of the laptop to separate it from its plastic shell.
    • Remove the battery.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
67,648 ポイント
335のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
138 メンバー
17,041のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 29
過去 30 日: 110
今までの合計 430
