メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ClickN Kids Tablet Touch Screen Display Replacement
必要な工具と部品
    1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: 手順 1、 1の画像 1
      • Start on the side with the camera. The screen side is black, the back side is colored
      • Insert a plastic opening tool into the space between the screen and the back side.
      FixBotに聞いてみる
      コメントを追加
    2. ClickN Kids Tablet Touch Screen Display Replacement: 手順 2、 1の画像 1
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      FixBotに聞いてみる
      コメントを追加
    3. ClickN Kids Tablet Touch Screen Display Replacement: 手順 3、 1の画像 1
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
      FixBotに聞いてみる
      コメントを追加
    4. ClickN Kids Tablet Touch Screen Display Replacement: 手順 4、 2の画像 1 ClickN Kids Tablet Touch Screen Display Replacement: 手順 4、 2の画像 2
      • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      • Once the ribbon cables are freed, separate the top and bottom sides.
      FixBotに聞いてみる
      コメントを追加
    5. ClickN Kids Tablet Touch Screen Display Replacement: 手順 5、 2の画像 1 ClickN Kids Tablet Touch Screen Display Replacement: 手順 5、 2の画像 2
      • Remove the yellow tape on the right side. Easiest side to get.
      • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
      FixBotに聞いてみる
      コメントを追加
    6. ClickN Kids Tablet Touch Screen Display Replacement: 手順 6、 1の画像 1
      • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
      • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
      • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
      FixBotに聞いてみる
      コメントを追加
    7. ClickN Kids Tablet Touch Screen Display Replacement: 手順 7、 2の画像 1 ClickN Kids Tablet Touch Screen Display Replacement: 手順 7、 2の画像 2
      • Be careful not to damage the display or screen case.
      • Pull the display from the top side to detach it from the screen case.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Kevin Finney
メンバー登録日: 03/22/15
562 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S4G4
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 40
今までの合計 8,394
