メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blu Grand M2 Display Replacement
必要な工具と部品
  1. Blu Grand M2 Display Replacement, Display: 手順 1、 2の画像 1 Blu Grand M2 Display Replacement, Display: 手順 1、 2の画像 2
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
    FixBotに聞いてみる
    コメントを追加
  2. Blu Grand M2 Display Replacement: 手順 2、 1の画像 1
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
    FixBotに聞いてみる
    コメントを追加
  3. Blu Grand M2 Display Replacement: 手順 3、 3の画像 1 Blu Grand M2 Display Replacement: 手順 3、 3の画像 2 Blu Grand M2 Display Replacement: 手順 3、 3の画像 3
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
    FixBotに聞いてみる
    コメントを追加
  4. Blu Grand M2 Display Replacement: 手順 4、 2の画像 1 Blu Grand M2 Display Replacement: 手順 4、 2の画像 2
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
    FixBotに聞いてみる
    コメントを追加
  5. Blu Grand M2 Display Replacement: 手順 5、 1の画像 1
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
    FixBotに聞いてみる
    コメントを追加
  6. Blu Grand M2 Display Replacement: 手順 6、 3の画像 1 Blu Grand M2 Display Replacement: 手順 6、 3の画像 2 Blu Grand M2 Display Replacement: 手順 6、 3の画像 3
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Christopher
メンバー登録日: 09/10/18
192 ポイント
1ガイドが承認済み
チーム
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018人のメンバー
GCC-LUSTER-F18S1G3
4 メンバー
12のガイドは作成済み
1件のガイドコメント
What type of torx screwdriver did you use?
npyles86 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 41
今までの合計 2,221
