メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus ZenBook UX330U Trackpad Replacement
必要な工具と部品
  1. Asus ZenBook UX330U Trackpad Replacement, Battery: 手順 1、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement, Battery: 手順 1、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement, Battery: 手順 1、 3の画像 3
    • Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
    • Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
    • Insert the bullet connector into the ground port of an outlet.
    • Make sure to keep the bracelet on at all times while disassembling your device, to prevent ESD to the components.
    FixBotに聞いてみる
    コメントを追加
  2. Asus ZenBook UX330U Trackpad Replacement: 手順 2、 2の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 2、 2の画像 2
    • Power off the device and make sure it is physically unplugged before starting any disassembly procedures.
    • Remove the eight 3.1 mm screws using the T5 Torx screwdriver.
    • Remove the longer 5.1 mm screw using the T5 Torx screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Asus ZenBook UX330U Trackpad Replacement: 手順 3、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 3、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 3、 3の画像 3
    • Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
    • Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
    • The rubber feet may be difficult to remove. Do not hesitate to use more force to remove the feet, if necessary.
    FixBotに聞いてみる
    コメントを追加
  4. Asus ZenBook UX330U Trackpad Replacement: 手順 4、 2の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 4、 2の画像 2
    • Press the suction handle on the center of the back cover, and gently lift up.
    • You may need to wiggle the back cover as you lift it in order to take it off easily.
    FixBotに聞いてみる
    コメントを追加
  5. Asus ZenBook UX330U Trackpad Replacement: 手順 5、 2の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 5、 2の画像 2
    • Unscrew the six 3.7mm screws using the Philips #0 screwdriver bit.
    • Be extra cautious when handling the battery. If the battery looks swollen or damaged, consult this guide.
    FixBotに聞いてみる
    コメントを追加
  6. Asus ZenBook UX330U Trackpad Replacement: 手順 6、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 6、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 6、 3の画像 3
    • Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
    • You may have to pull back the black tape located on the bottom right motherboard connector screw. This tape is not necessary for the functionality of the device and can be discarded if necessary.
    FixBotに聞いてみる
    コメントを追加
  7. Asus ZenBook UX330U Trackpad Replacement: 手順 7、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 7、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
    • You may have to hold down the black tape in order to be able to lift up the connector.
    • To reconnect the motherboard ribbon, simply press the ends of the ribbon on top of the connector. This should require minimal force.
    FixBotに聞いてみる
    コメントを追加
  8. Asus ZenBook UX330U Trackpad Replacement: 手順 8、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 8、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 8、 3の画像 3
    • Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
    • Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
    FixBotに聞いてみる
    コメントを追加
  9. Asus ZenBook UX330U Trackpad Replacement: 手順 9、 2の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 9、 2の画像 2
    • Gently lift the battery out of the chassis of the device.
    • Make sure that you do not bend the battery.
    FixBotに聞いてみる
    コメントを追加
  10. Asus ZenBook UX330U Trackpad Replacement, Trackpad: 手順 10、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement, Trackpad: 手順 10、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement, Trackpad: 手順 10、 3の画像 3
    この手順で使用する道具:
    • Use the tweezers to unlatch the clasp holding the ribbon cable
    FixBotに聞いてみる
    コメントを追加
  11. Asus ZenBook UX330U Trackpad Replacement: 手順 11、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 11、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 11、 3の画像 3
    • Using the tweezers again, pull on the blue plastic tab with “TP” printed on it.
    • Be careful not to pull directly on the white part of the ribbon cable. Doing so could result in damage to the ribbon cable itself.
    FixBotに聞いてみる
    コメントを追加
  12. Asus ZenBook UX330U Trackpad Replacement: 手順 12、 2の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 12、 2の画像 2
    • Remove the strip of tape by grabbing the end of it with the blunt nose tweezers and pulling back.
    FixBotに聞いてみる
    コメントを追加
  13. Asus ZenBook UX330U Trackpad Replacement: 手順 13、 3の画像 1 Asus ZenBook UX330U Trackpad Replacement: 手順 13、 3の画像 2 Asus ZenBook UX330U Trackpad Replacement: 手順 13、 3の画像 3
    • Remove the three 2.5 mm screws across the top of the trackpad with the Philips #0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  14. Asus ZenBook UX330U Trackpad Replacement: 手順 14、 1の画像 1
    • Slightly lift the trackpad from the top edge and pull it away from you.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Hasan Akpunar
メンバー登録日: 09/20/19
1,475 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 45
今までの合計 1,762
