メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus X551CA Hard Drive Replacement
必要な工具と部品
  1. Asus X551CA Hard Drive Replacement, Keyboard Plate Cover: 手順 1、 1の画像 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    FixBotに聞いてみる
    コメントを追加
  2. Asus X551CA Hard Drive Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    FixBotに聞いてみる
    コメントを追加
  3. Asus X551CA Hard Drive Replacement: 手順 3、 1の画像 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    FixBotに聞いてみる
    コメントを追加
  4. Asus X551CA Hard Drive Replacement: 手順 4、 3の画像 1 Asus X551CA Hard Drive Replacement: 手順 4、 3の画像 2 Asus X551CA Hard Drive Replacement: 手順 4、 3の画像 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    FixBotに聞いてみる
    コメントを追加
  5. Asus X551CA Hard Drive Replacement: 手順 5、 1の画像 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    FixBotに聞いてみる
    コメントを追加
  6. Asus X551CA Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. Asus X551CA Hard Drive Replacement: 手順 7、 1の画像 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    FixBotに聞いてみる
    コメントを追加
  8. Asus X551CA Hard Drive Replacement: 手順 8、 1の画像 1
    • Once it is free, remove the hard drive from its internal cavity.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
48 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Brandon
メンバー登録日: 04/01/14
2,838 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G22
5 メンバー
15のガイドは作成済み
8件のガイドコメント
You mixed up the red and green screws, sizes are wrong.
The red screws are 9.5 not 14.3!
the yellow screws are 4.3 (mixed up with 14.3 ?) not 9.5 !
You do NOT need to remove the ribbons, just use a small screwdriver.
Tony - 返信 共有
Excellent work !
Drew Lawrence - 返信 共有
Same issue as Tony on 09/03/2014
The screw sizings are mixed up. The red screws are 9.5, not 14.3
The yellow screws are 14.3 not 9.5. Please fix the repair guide text
Mevlan Coma - 返信 共有
It should be fixed now! Thanks to both of you for the tip. By the way, you can always edit the text yourself. ;)
Jeff Suovanen - 返信 共有
Thanks for the info!
Abe Aleman - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 75
今までの合計 67,974
