メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement
必要な工具と部品
  1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Asus Transformer Pad Infinity Teardown: 手順 1、 1の画像 1
    • First, turn the power off
    FixBotに聞いてみる
    コメントを追加
  2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 2、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 2、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
    • Unlock screen casing tabs
    • Push tab with screwdriver to the right until it clicks
    • You should see a small arrow in the bottom of the port
    • Unlock the tabs in both docking station guide ports.
    FixBotに聞いてみる
    コメントを追加
  3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 3、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 3、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Use spudger to push upward on the small plastic tabs on top of the docking station guide ports.
    • Insert the flat side of another spudger to start freeing the bottom of the screen from the case.
    FixBotに聞いてみる
    コメントを追加
  4. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 4、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 4、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 4、 3の画像 3
    • Use your spudger to open the four plastic tabs located on either side of the tablet.
    • These tabs are very fragile.
    • Remove the screen from the body
    FixBotに聞いてみる
    コメントを追加
  5. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 5、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 5、 2の画像 2
    • There is an internal power switch next to the battery connector, that will kill power to the entire device while you're working on it.
    • Don't forget to switch it back on when you're reassembling!
    FixBotに聞いてみる
    コメントを追加
  6. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 6、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 6、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 6、 3の画像 3
    • Use your spudger to release the two digitizer ribbon cables from the mainboard.
    • Located on the left side of the tablet between the micro-HDMI and the microSD slot.
    • Use your spudger to release the LCD cable from the back of the LCD.
    • Set aside for later dissection.
    FixBotに聞いてみる
    コメントを追加
  7. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 7、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 7、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 7、 3の画像 3
    • To remove the front facing camera (right):
    • Use your spudger to unlock the ribbon cable
    • Slide the camera out
    • To remove the rear facing camera (top):
    • Apply light lifting pressure to unplug it from it's socket
    • Remove the backup battery on the right side:
    • Unplug the cable from the motherboard with your spudger
    FixBotに聞いてみる
    コメントを追加
  8. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 8、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 8、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 8、 3の画像 3
    • Remove the motherboard, daughterboard, and dock connector
    • Unscrew 14 points
    • Unplug the speaker from the motherboard before removing it
    • Reveal the battery connector:
    • Flip the motherboard from the top edge of the tablet down (towards the battery).
    • Unplug with light pressure from your spudger.
    • Disconnect the motherboard from the daughterboard:
    • Unlock the ribbon cable on the back side of the daughterboard
    FixBotに聞いてみる
    コメントを追加
  9. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 9、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 9、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 9、 3の画像 3
    • Remove the battery:
    • Remove screws (eight)
    • Use your spudger underneath the battery between the 2 cells to work it free
    FixBotに聞いてみる
    コメントを追加
  10. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 10、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 10、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 10、 3の画像 3
    • Remove the speaker:
    • Use your spudger underneath, and work it free
    • Remove the bottom screen locking mechanism:
    • Lift pieces out
    FixBotに聞いてみる
    コメントを追加
  11. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 11、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 11、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 11、 3の画像 3
    • Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
    • Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
    FixBotに聞いてみる
    コメントを追加
  12. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 12、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 12、 2の画像 2
    • With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
    FixBotに聞いてみる
    コメントを追加
  13. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 13、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 13、 2の画像 2
    • The back side of the motherboard
    FixBotに聞いてみる
    コメントを追加
  14. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 14、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 14、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 14、 3の画像 3
    • Motherboard backside closeups
    FixBotに聞いてみる
    コメントを追加
  15. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 15、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 15、 2の画像 2
    • The front side of the motherboard is where all the action is.
    • Tegra 3 quad core processor T33-P-A3
    • 2x Elpida memory J4216EBBG-GNL-F
    • Realtek? ALCS631
    • Hynix H26M64002BNR e-NAND
    FixBotに聞いてみる
    コメントを追加
  16. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 16、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 16、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 16、 3の画像 3
    • Front side motherboard closeups
    FixBotに聞いてみる
    コメントを追加
  17. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 17、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 17、 2の画像 2
    • Front and back of the daughterboard.
    FixBotに聞いてみる
    コメントを追加
  18. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 18、 2の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 18、 2の画像 2
    • The back of the LCD.
    FixBotに聞いてみる
    コメントを追加
  19. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 19、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 19、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 19、 3の画像 3
    • Close-ups.
    • That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
    • ...and yes, it still works after reassembly. Thanks for asking.
    FixBotに聞いてみる
    コメントを追加
  20. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: 手順 20、 1の画像 1
    • Disconnect the camera connectors from the board.
    FixBotに聞いてみる
    コメントを追加
  21. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 21、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 21、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 21、 3の画像 3
    • Flip the pieces that secure the ribbons to the motherboard up. This is for the front facing camera.
    • Before removing the ribbon connectors, check for a release mechanism. Also make sure it is not a ZIF connector. Doing so can help prevent permanet damage.
    • Take out the ribbon connected to the motherboard. Pull the ribbon cable straight out of the soket to disconnect them.
    • Only follow what is needed for the camera you are replacing. If both cameras need replacement, do both steps. Otherwise, follow the one designated for the camera you need to replace.
    • The first photo shows the overall image. The second photo shows the step for the front-facing camera. The third photo shows the step for the rear camera.
    FixBotに聞いてみる
    コメントを追加
  22. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 22、 1の画像 1
    • Take the both cameras out of tablet.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
8人の作成者と共同で作成されました。
Allison Poh
メンバー登録日: 10/20/15
549 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015人のメンバー
UMASSD-GULBRANDSEN-F15S5G1
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 817
