メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus CM1745 Hard Drive Replacement
必要な工具と部品
  1. Asus CM1745 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 Asus CM1745 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
    • Remember to unplug the device before beginning disassembly, to make sure that no power is running through the device during repair. You could risk hurting yourself and/or damage sensitive components.
    FixBotに聞いてみる
    コメントを追加
  2. Asus CM1745 Hard Drive Replacement: 手順 2、 2の画像 1 Asus CM1745 Hard Drive Replacement: 手順 2、 2の画像 2
    • Remove the two cables from the rear of the Hard Drive.
    • Unscrew the two screws attached to the Hard Drive with a Phillips #0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Asus CM1745 Hard Drive Replacement: 手順 3、 3の画像 1 Asus CM1745 Hard Drive Replacement: 手順 3、 3の画像 2 Asus CM1745 Hard Drive Replacement: 手順 3、 3の画像 3
    • Flip the computer over and remove the sidepanel on that side.
    • Remove the Phillips #0 screw(s) attached to the Hard Drive on this side.
    • Once removed, slide the Hard Drive out the back. Remember the orientation that the Hard Drive was in.
    FixBotに聞いてみる
    コメントを追加
  4. Asus CM1745 Hard Drive Replacement: 手順 4、 3の画像 1 Asus CM1745 Hard Drive Replacement: 手順 4、 3の画像 2 Asus CM1745 Hard Drive Replacement: 手順 4、 3の画像 3
    • Take your replacement Hard Drive (Picture does not necessarily represent the exact Hard Drive) and place it in the same slot as the old one.
    • Replace the two screws on the front of the cage and the screw(s) on the back.
    • Replace the power and data cables on the back of the hard drive.
    FixBotに聞いてみる
    コメントを追加
終わりに
If everything looks to be in the right place, you should be able to boot the computer and boot into the BIOS to check if the Hard Drive is recognized. You will have to install a new Windows installation if this Hard Drive was your only Hard Drive.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
TC Fowlar
メンバー登録日: 10/30/19
896 ポイント
5のガイドは作成済み
チーム
University of Memphis, Team S4-G2, Kim Fall 2019 University of Memphis, Team S4-G2, Kim Fall 2019人のメンバー
UM-KIM-F19S4G2
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 98
今までの合計 4,482
