メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Anker SoundCore 2 Battery Replacement
必要な工具と部品
  1. Anker SoundCore 2 Battery Replacement, Front Panel: 手順 1、 2の画像 1 Anker SoundCore 2 Battery Replacement, Front Panel: 手順 1、 2の画像 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    FixBotに聞いてみる
    コメントを追加
  2. Anker SoundCore 2 Battery Replacement, Battery: 手順 2、 3の画像 1 Anker SoundCore 2 Battery Replacement, Battery: 手順 2、 3の画像 2 Anker SoundCore 2 Battery Replacement, Battery: 手順 2、 3の画像 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Be careful not to damage the rubber gasket around the speaker mount plate.
    • Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
    FixBotに聞いてみる
    コメントを追加
  3. Anker SoundCore 2 Battery Replacement: 手順 3、 3の画像 1 Anker SoundCore 2 Battery Replacement: 手順 3、 3の画像 2 Anker SoundCore 2 Battery Replacement: 手順 3、 3の画像 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #1 screwdriver. Some variants have 2 screws.
    • Carefully remove the bluetooth antenna wire from the left of the board. It pulls up without much pressure.
    • Flip up the motherboard to expose the battery.
    FixBotに聞いてみる
    コメントを追加
  4. Anker SoundCore 2 Battery Replacement: 手順 4、 2の画像 1 Anker SoundCore 2 Battery Replacement: 手順 4、 2の画像 2
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
    FixBotに聞いてみる
    コメントを追加
  5. Anker SoundCore 2 Battery Replacement: 手順 5、 2の画像 1 Anker SoundCore 2 Battery Replacement: 手順 5、 2の画像 2
    • Unplug the wire that connects the battery with the motherboard.
    • Battery specs: 2 x 18650 2600mAh soldered in series (to bring voltage to 7.4V).
    • Can safely be upgraded to 2 x 18650 3500mAh for additional capacity.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Tripp Lersch
メンバー登録日: 01/14/21
411 ポイント
4のガイドは作成済み
チーム
8件のガイドコメント
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - 返信 共有
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - 返信 共有
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - 返信 共有
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis - 返信 共有
same. i tried cleaning and drying, even an improvised other battery but nothing happens. charging only ever shows red light.
JohnLS17 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 153
過去 30 日: 727
今までの合計 24,680
