メインコンテンツにスキップ
Amazon Echo Show 10 3rd Gen Display Replacement
必要な工具と部品
  1. Amazon Echo Show 10 3rd Gen Display Replacement, Display: 手順 1、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement, Display: 手順 1、 2の画像 2
    • With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set aside.
  2. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 2、 1の画像 1
    • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
  3. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 3、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 3、 2の画像 2
    • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
    • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
    • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
  4. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 4、 1の画像 1
    • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
  5. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 5、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 5、 2の画像 2
    • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
    • Place the shell aside.
  6. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 6、 1の画像 1
    • Tilt the device so that the underside of the display and its neck are facing you.
    • You may need help holding it in this position. Alternatively, you could place the device on a soft surface so it doesn't get damaged.
    • Use a T6 Torx screwdriver to remove the two 5mm screws from the underside of the display neck.
  7. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 7、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 7、 2の画像 2
    • Lift the plate up to remove it from the neck of the device.
    • Set it aside for reassembly.
  8. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 8、 1の画像 1
    • Use an opening tool to flip up the small locking flap on the ribbon cable connector located in the center of the exposed underside of the display neck.
    • Gently pull the cable out.
  9. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 9、 1の画像 1
    • Tilt the device so it is in the upright position.
    • Use a TR10 Torx Security screwdriver to remove the four 11 mm screws from the top of the display neck.
  10. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 10、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 10、 2の画像 2
    • Gently lift the display and its connecting neck off of the base.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Macy Ormand
メンバー登録日: 09/13/23
1,094 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Fall 2023 Western Carolina University, Team 1-4, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G4
4 メンバー
6のガイドは作成済み
4件のガイドコメント
any idea where to purchase a replacement display?
Don Jackson - 返信
Were you able to source a replacement display? I'm having troubles finding one. Thanks
Jeg4 -
where can I buy a replacement display for echo 10 3rd gen?
Tomasz K. - 返信
Wenn ihr eine Quelle gefunden habt wäre eine info schön ich suche nun auch nach einem kleinen missgeschick...
Jan Pfotenhauer - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 37
過去 30 日: 124
今までの合計 1,892
