はじめに
If your 8BitDol Pro 2 controller is not turning on, losing charge quickly, or not holding a charge at all, the battery pack may need to be replaced. Over time, rechargeable batteries can wear down and lose their ability to function the correct way.
This guide will walk you through removing and replacing the battery pack. This is a simple and quick repair that requires no tools.
Before you begin, make sure that the controller is powered off.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
