メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toyota Camry XV20シリーズは、トヨタのセダン、Camryの第6世代です。
Backspeaker shortcut rear speakers?
Hi.
I have now destroyed my cdplayer thanks to a shortcut in my rear speakers.
How do i change the rear speakers wthout destroying anything at the back of my car?
Can someone give me a step-by-step writedown on how to do it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
What happened to your CD player that makes you believe that it is destroyed from a bad speaker? What have you tried so far to find the error? I think I would check the wiring harness first. If you give us more of a description of what is going on with your CD player and speakers, we could try to assist you further.
さんによる 共有
There is a certain sound in the speakers when it is a short circuit. I have tried a lot of things, but it was when i tried to connect an Amplifier to the back speakers i really knew. As you know you got to have separate cables from the Amplifier to the speakers. When i started the system the Amplifier instantly switched to " safe mode". ( sorry for my bad spelling/grammar, hope you understand what i mean )
さんによる 共有
Have you checked you original wiring harness , just to make sure there is no short circuit in the wiring? I would use a separate speaker to make sure that everything else is working okay. Temporarily replace one rear speaker and see what it does.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
The package tray needs to come out in order to replace the speaker covers or speakers.
1. Remove the 3 bolts attaching the deck to the frame
2. Remove the side panels that hold down the deck so you really have to take these off. They should just snap off.
3. Remove the high mounted stop light.
4. Either remove the back seats or try to fold the back seats down and see if that gives you enough room.
5. To remove the deck you first need to go in through your trunk and you'll see 4 white clips. Push these up with some pliers, then from the inside just tug it away. Be careful shimmying the tray out, since you do not want to break it.
6. Remove old speakers. They should be held down by 3 screws.
画像
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Robert さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 38
今までの合計 12,373
