How to fix AC?
AC doesn't work. Compressor bad or something else?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Vehicle ac repairs are not diy friendly. All ac systems are sealed at factory assembly because refrigerant is under pressure at all times like spray paint cans. 98% of ac problems are leaks no one wants to find but run to stores for refill kits, refilling or topping off....a leaking system. Sealer is never used at factory assembly because it will ruin a system. Sealer used in refill kits will ruin a system with repair costs higher than if a leak was found and repaired. Service valves may leak if caps aren't tightened. 9+ years can be considered as wear and tear when a leak occurs, compressor clutch coil fails, air gap opens preventing clutch engagement, etc. A can of leak detector (no sealer) and an inexpensive uv black light can find dye leaking out from; compressor front seal, fittings, aluminum parts.
さんによる 共有
コメントを追加
