メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
長年使用されているセパレート型エアコン、R407冷媒使用
Ac indoor display e1 error
My ac indoor display e1 error what happened is there any operation mistake or what how can repair
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I asked FixBot your question and its reply is in italics. FixBot AI can make mistakes. Verify critical details from reliable sources.
I [FixBot] couldn't find a specific troubleshooting guide for this exact error in iFixit's knowledge base, but information found elsewhere on the web indicates that an E1 error code on a split air conditioner typically points to one of a few common issues:
  • Temperature Sensor (Thermistor) Failure: The indoor room temperature sensor is disconnected, shorted, or faulty, preventing the control board from reading the ambient temperature.
  • Communication Fault: A loose, corroded, or damaged wiring connection between the indoor and outdoor units.
  • Control Board / Button Glitch: A temporary electronic latch or stuck button on the display panel requiring a system reset.
To troubleshoot, try cutting power to the air conditioner at the circuit breaker for 5 to 10 minutes to allow the control board to fully reset. If the error immediately returns, inspect the indoor unit's wiring connections and temperature sensor near the evaporator coil.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Suryakant Macwan さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 14
過去 30 日: 14
今までの合計 14
