メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月20日に発売されたAppleのメインストリームiPhone 11は、6.1インチのLCDタッチスクリーン、デュアルカメラを搭載し、6色展開です。iPhone XRの後継機にあたります。
Unexpected working on speaker
I purchased a second-hand iPhone 11 and replaced the screen and the battery. I’m not certain if this started after the replacements, but when someone calls me, the ringtone plays, then stops after a while, starts over, stutters, and so on. Sometimes, there is no sound from the phone at all. Similar stuttering issues also occur within the ringtone selection menu. Could there be an issue with the battery? I have already tried a clean install, but that did not resolve the problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like a speaker issue to me. If you followed the iFixit Battery replacement guide then you took the speaker out during the repair, and I'm wondering if there's an issue with its connection.
The speaker gets its signals from two copper contact points on the charging port flex cable, circled here in this image.
画像
You'll need to open the phone back up and pull the speaker. Check to verify there isn't anything blocking either of those pads, then check the spring pins on the speaker itself to verify they're not bent or broken. Here's a picture of those.
画像
If that doesn't help, you might want to just go ahead and replace the speaker; they're not particularly expensive if you shop around on sites like AliExpress, eBay or Amazon.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Semih S. Avcılar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 29
今までの合計 29
