メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Yamaha P-125は、素晴らしいピアノ性能とユーザーフレンドリーでミニマルなデザインを融合させたコンパクトなデジタルピアノです。 持ち運びが簡単で非常に使いやすいこの楽器で、自分好みのピアノ演奏の喜びを体験できます。
ghost press on the rythm button
So i bought this used P-125a and occasionally the rythm would activate itself. But today it got so bad that everytime I turn on the keyboard the rythm would activate, it's still running as I write this, I tried holding down the metronome button without the rythm and it activated function since holding rythm+metronome does that, so it leads me to think that rythm is being continuously pressed down, in one instance function was activated without pressing down anything leading me to suspect that metronome button could also have the same problem. The piano was mostly clean on purchase save for this volume slider which has collected dust.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
My guess is that the tactile switch underneath the button is leaking or contaminated, causing intermittent false button presses.
If you'd like to try something before taking it apart, press the affected button about 100 times. In some cases, this can restore normal operation. However, disassembling the unit and repairing or replacing the switch is the most reliable fix.
The Yamaha P-125 service manual can also be downloaded from sites such as Elektrotanya.
https://elektrotanya.com/yamaha_p-125b_w...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello there, so about 2 hours before you published your comment i was trying to practice and it kept turning on and i crashed out and started slamming the button aggressively like 25 times then tuned of the piano, and that actually fixed it😭😭😭.
I have been playing since yesterday and so far there has only been 1 very brief instant of the ghost press otherwise it has been working fine.
Also i was trying to find that service manual but couldn't find it, thanks for the link.
さんによる 共有
コメントを追加
回答を追加する
sadique arman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 36
過去 30 日: 36
今までの合計 36
