メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iRobot Roomba J7 Plusの修理ガイドおよびトラブルシューティング情報です(2021年9月発売)。
Fluid Sensor issue (Error 1014)
Hi everyone,
I'm having an issue with my Roomba Combo J7+ (water tank / mop model). The robot keeps reporting a low water level error even though the water tank is completely full.
Here's what I've already tried:
  • Removed and reseated the water tank several times until it clicks.
  • Cleaned the tank and the robot's tank contact area with a dry cloth.
  • Agitated the tank vigorously with warm (not hot) water to free the float.
  • Left warm water inside the tank for a few minutes, then rinsed and reinstalled.
  • Restarted the robot by holding the CLEAN button for ~10–20 seconds.
I also noticed something important: I can reach the float through the fill hole and move it with my finger. It seems to move, so it doesn't appear to be physically stuck. However, the error still comes back.
My questions:
  1. Does anyone know where exactly the Hall sensor (the magnetic sensor that reads the float) is located on the robot body? Is it in the tank docking area at the rear?
  2. Could the float's magnet have failed or become weak, even though the float itself moves?
  3. Has anyone successfully fixed this without replacing the tank or the robot?
  4. If the Hall sensor itself is faulty, is it replaceable, or does it require a board-level repair?
Any help would be greatly appreciated. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your float test was the right instinct, but moving under a finger is not the test. The float has two separate jobs: move freely, and carry its magnet close enough to the reader. Either one failing gives the same low-water error.
1. Does it actually float? Fill the tank, invert it slowly, watch the float rise on its own. If it pivots when poked but sits low or sinks, the float is the fault. Usually a hairline crack letting water in, or scale on the guide pin.
2. Is the magnet still there and still aligned? Tank out, run a small fridge magnet along the outside of the tank where the float sits. You should feel a pull through the plastic. No pull where you can feel the float means the magnet has come loose inside the float, and that tank is done.
3. Test the robot side with the tank out. Machine on, hold a fridge magnet against the reader area in the tank bay for a few seconds. If the warning clears, the reader is fine and the tank is the problem. If nothing changes at all, the reader or its wiring is the problem.
4. The reader sits in the tank bay on the Combo models, not inside the tank, and it is board-mounted. No field replacement. If step 3 points there, check the contact pads and the ribbon at the bay for corrosion or a cracked solder joint first, then it is iRobot support or a board-level repair.
One caution: warm water agitation is the right move, but never hotter than warm, and rinse with distilled if your water is hard. Scale film on the guide pin will bind the float again within a week.
Most of these end at step 2 or 3, and the cheap fix is a replacement tank rather than a robot. Do the two magnet tests before spending on either, because they are the only thing that tells you which part is wrong.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi Anthony, thanks for the detailed troubleshooting steps. Results:
Test 1: Float rises on its own when I invert the tank — not stuck, not full of water.
Test 2: Neodymium magnet outside the tank: no pull at all. Magnet on a screwdriver tip through the fill hole, touching the float directly: nothing. Small pieces of oxidized metal came out. So the magnet inside the plastic float came loose and corroded away. The float still floats, but the magnet is gone.
Test 3: Pressed the tank presence button — robot confirmed the tank and did not complain about fluid level. So the Hall sensor seems fine; it just has no magnet to read.
Looks like the tank is the fault. Do you think the corroded magnet could have damaged anything else inside the tank, or is a replacement tank the only fix? Also, is there any way to test the Hall sensor directly with a magnet to confirm it still reacts? Thanks again — this really saved me from guessing, and I appreciate the help.
さんによる 共有
コメントを追加
回答を追加する
Pablo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 47
過去 30 日: 116
今までの合計 116
