メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Infinix HOT 30 Androidスマートフォン(モデル番号:X6831)の修理、分解、トラブルシューティング情報。6.78インチ 90 Hzディスプレイ、MediaTek Helio G88プロセッサ、50 MPリアカメラ、5000 mAhバッテリーを搭載しています。
The phone Camera problem
My phone camera isn't responding
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@alaminmuhammad you should clarify which camera and when does it not respond. This could be a bad camera module or a software issue. Try to start your phone in safe mode. To get into safe mode turn off your phone, turn it back on, and hold the Volume Down button as soon as the Infinix logo appears. Check your camera in that mode. Since safe mode disables all third-party apps and if you camera works in that, you know that this is an issue with a third part App that maybe blocking access to the camera. You will need to uninstall those Apps until you have access again. If your camera does not work in safe mode either, it is most likely the camera module that has failed.
Since iFixit does not yet have a specific guide for this, use something like this video for that. Start at 6:40 for the disassembly. Of course, skip the parts that do not pertain to the mainboard and the cameras itself. You do not have to completely disassemble your phone for this :-)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alamin Muhammad さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 57
今までの合計 67
