After it get wet
My airpods alpha is not working after it fall in water it's light is continuously on and pods are connected after they in case it's not working properly
Hello, @kshitijramteke
First off, DO NOT ATTEMPT TO USE YOUR AIRPODS CASE FURTHER, AS IT WILL CAUSE MORE DAMAGE THAN THE WATER HAS ALREADY CAUSED. DO NOT PUT IT IN A BAG OF RICE, AS IT HAS ALREADY BEEN PROVEN TO MAKE YOUR PROBLEM WORSE IN THIS ARTICLE. I HIGHLY SUGGEST THAT YOU GET A NEW AIRPODS CASE, AS THE CASE IS BASICALLY IMPOSSIBLE TO REPAIR WITHOUT THE RISK OF SEVERELY DAMAGING THE COMPONENTS.
Regards,
T
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 33
今までの合計 56
