メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleブランドの7インチタブレット。修理に必要な工具はこじ開けツールとドライバーのみ。モデル番号:ME370T。
Use of external mic thru audio jack
Can you please tell me if the Nexus 7 supports the use of a headphone/mic combo so that when the audio jack is inserted the internal mic is bypassed and the external mic provides the source of audio. In other words does it work the way any ordinary cell phone does? I ask because I have received 2 units and neither works in this way (the internal mic continues to be used when I insert a plug that includes a mic). Google seems to think they muct be defective (e.g., a solder joint is bad) but given that you have taken the tablet apart, I thought you could provide a definitive answer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
The Nexus 7 has a normal 3-pole headphone-only jack at the bottom, and two microphones: one on the top left (on a little daughterboard plugged into the mainboard) and one on the lower left edge (soldered directly to the mainboard) about 1" above the docking pins.
I don't know why they chose to do that. It is possible to replace the jack with a 4-pole and reroute the top microphone through it so it behaves as you would expect, but it's not a simple hack and it requires a willingness to shred your warranty and the equipment & skill to work with small SMD parts and flex-cable. Also, physically fitting and securing a 4-pole jack will probably involve epoxy and a dremel in addition to soldering little jumper wires.
The Realtek ALC5642 - the (micro|head)phone driver chip - has Echo Cancellation and Noise Suppression built-in; one potential issue is whether the boost gain on the microphones (which is software selectable when the chip is used in PCs) is fine the way it is set, or if it can be tweaked. I haven't yet looked into how Android deals with this, nor do I know if it is a software or firmware setting - I strongly suspect it is software as that is the only way that makes sense, but putting in a 4-pole jack in the first place makes the same kind of sense and they didn't do that.
I suspect the second microphone strips out ambient noise, such as the noise of the speakers - which it is much closer to - when the top mic is being used... that would be an easy way to prevent feedback, but it wouldn't be necessary when using a headset w/microphone. If it doesn't cause any problems I'll leave it alone so everything works the same without headphones.
I'll be tearing into my N7 next week to experiment with this stuff... I'll post results when I have them.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I realize this was an old topic, but for all those who find it these days...
The 2013 Nexus 7 DOES INDEED support the 4-pole stereo headphone/microphone standard used by all modern Android devices.
I verified it to be certain using my "Beats" mobile phone headset that came with my HTC One, and I get Stereo Audio, and the headset microphone over-rides the N7's internal microphones.
Also... the pushbutton on the headphone cord also works... in music player it's a Pause, other apps may use it differently.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I recieved an email back from Google today stating the Nexus 7 does not support 4 pole headphone/mic headsets.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Buy Apple IPadAir it has this feature.
さんによる
コメントを追加
回答を追加する
irafuchs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 23,185
