メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Makita XDT08は、プロの現場向けに設計されたコードレスインパクトドライバーです。ブラシレスモーターを搭載し、18V LXTリチウムイオンバッテリーに対応しています。本体サイズは5-7/8インチ x 3-1/4インチ x 9-1/8インチ、1/4インチの六角軸(ヘックス)を採用しており、様々な締め付けや駆動作業に高いトルクとスピードを発揮します。
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 36
今までの合計 81
