Camera lens auto focus not working
Why my camera lens auto focus not working
Hello,
What lens are you using? Please look at whatever one you're are using, and on either the left or right side (probably the left), there should be a AF and MF toggle switch, which controls whether the camera is on Auto Focus (AF), or Manual Focus (MF). In this case, you want to switch it to Auto Focus (AF). If that doesn't fix anything, go into your settings, and scroll until you see FOCUS MODE. Make sure that is also switched to Manual. Lastly, make sure you are depressing the shutter button only halfway. You should feel it go down, but you shouldn't feel the click. Hope it helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 21
過去 30 日: 32
今までの合計 32
