Replace forward lower control arm
How do I replace the forward lower control arm and shock on the driver's side rear
Here's the rear suspension arm removal and installation procedure from the 2008 Pathfinder service manual.
The shock absorber is also removed during the above procedure
The link works OK for me.
Here are images of what is shown in the link.
(click on images)
このアンサーは役に立ちましたか?
The link is not coming up
The most important thing is to have th proper tools. The firat tool you need is an impact with proper sockets. A jack and jack stands. Next you might need replacement HDW: nuts bolts bushings etc. Be very aware of any potential things that can create serious injury to you. IE strut springs
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 20
過去 30 日: 46
今までの合計 46
