メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
プロフェッショナルオーディオ機器とは、レコーディングスタジオ、ライブ音響、放送、その他さまざまな用途のプロの現場で使用するために設計された、高品質な音響機器やシステムの総称です。
Do you fix QSC Power amps?
I have a 4 channel QSC pld 4.5 and there Is only buzzing noises coming from each channel
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi, @warrenreed96485
We don't, but you can! Try to find a guide and the tools to fix your problem, or try to unplug and replug in the connection for the speakers! That worked for me!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@warrenreed96485 iFixit doesn’t actually fix things for people. The site is a place for people to learn repair for themselves—the “i” in iFixit is you! For this repair, I’d start by checking Switch Mode Power Supply (SMPS). Reason for is that you have buzzing on all channels which is typically an error with an external ground loop from the input source or teh SMPS.
See if we can narrow it down. Disconnect all the input cables from the amplifier, leave only the speaker outputs and the AC power cable connected. Turn the amp on. If the buzzing completely stops, the amp is functioning normally, and the noise is an issue with an upstream mixer, a damaged audio cable, or a ground loop between your equipment racks.
If the amp still buzzes with nothing connected to the inputs, unplug it and connect it to a complete different outlet/circuit. Faulty dimmer switches, fluorescent lighting, or other failing electrical equipment on the same circuit phase can directly cause a hum into the amps power cord.
If the buzzing persists on a clean circuit with isolated inputs, the SMPS is failing to filter the power. For that you would have to check all the caps on the SMPS to see if those are actually still filtering. Remember to discharge all the caps after you disconnect the power from the SMPS. Those hold a charge reasonably long and can zap you pretty good if not discharged.
Let's see if we find some schematic for this amp to help you further.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Warren Reed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 42
今までの合計 42
