メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
New Nintendo 3DS LLは、New Nintendo 3DS LLとして販売され、日本では2014年10月11日、北米では2015年2月13日に発売されました。
New 3DS XL constant error screen
I tried to boot up my 3DS after 1-2 years since I last touched it, when plugged into a charger the charging light only shows up after 10-20 minutes of charging, once I turn it on it works for a few minutes and then starts stuttering and finally freezes at the "An error has occurred" screen, holding the power button doesn't turn it off unless I take the battery out. The blue light goes off briefly before coming back on just before the error screen shows up.
So I've swapped the battery, disabled the wifi, removed the SD card but the error screen still shows up after working for 1-2 minutes
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
First: Is the New 3DS XL modded?
Try to get in the recovery menu with doing the following:
turning off the console and holding down L + R + A + D-Pad Up while pressing the power button
Does it work now? If yes, try to update the console and see what happens.
Since it does work for a few minutes, it does sound like software/firmware issues.
Please keep us posted!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi, after updating and leaving it on for about 1 hour it seems like it worked, It stopped freezing!
Booting into the recovery mode to update was one of the options I had in mind but I was afraid it'd freeze mid-update but I decided to risk it.
Thank you very much!
さんによる
Ah glad that it’s solved now! My pleasure :)! Have fun gaming!
さんによる
コメントを追加
回答を追加する
Hsia Hz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 42
今までの合計 42
