メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Buds2は、オリジナルモデルであるGalaxy Budsの後継機です。2021年8月27日に発売されました。
The Case Hinge has Failed
My Galaxy Buds2 case hinge has failed. It won't open all the way and won't shut properly making charging difficult. I have to put something on top to keep them shut despite the magnet closure. Is it worth it to try to repair the hinge? Should I try to replace the case, or should I just go ahead and get the newest model?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Do you have any visible damage, cracks, or the like in the shell? Can you see anything on the outside that is misaligned?
There is a moderate risk that this is not repairable, but if you anyway will be looking for a replacement case, I would suggest attempting to open the charging case to see if you can fix the hinge. The case should not be hard to open. With a bit of luck something has just gotten misaligned and you can pop it back into place. iFixit does not have a proper guide for opening the case, but they do have a teardown you can watch at Youtube where they open the case at 2:35, you can watch it by following this link.
While you work on your device, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
If the inside of the case is beyond repair you can always go ahead and buy a replacement case, they're not that expensive.
Please respond with how this went!
Good luck,
Cheers
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ronald Lance Teel Byers さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 52
今までの合計 84
