メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How do you replace a failed speaker?
My speaker on my minimal phone MP01 failed after about nine months of use. The only thing that's been consistent and loud has been my alarm in the morning. I want to know if anyone knows how or has figured out how to repair the speaker on this phone without damaging it and what parts would be needed to do so.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Firstly Turn the phone off completely.Remove SIM Tray Use an ejector tool to take out the SIM tray.Pry the Shell: Carefully wedge a thin prying tool into the seam at the top corner of the back cover. Slide it around to unclip the shell.Unscrew the Body: Remove the two main screws holding the secondary inner frame. Note that one might be hidden under a small white sticker.Lift the Board: Gently lift the main board, watching out for the delicate antenna wires attached to the shell.Swap the Speaker: Use tweezers to lift the old speaker out of its lower housing, drop the new one in, and reassemble everything in reverse.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I appreciate your response. I'll try that the only problem though is I'm not quite sure what the particular speaker is like the model number or anything to look it up by.
さんによる 共有
コメントを追加
回答を追加する
Willow Oakes さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 7
過去 30 日: 29
今までの合計 129
