メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
様々なテレビブランドとスタイルの修理ガイドならびにサポート
Make monitor out of tv screen
I have a Curtis LED1337A that doesn't work and I want to use its screen to make a PC monitor from scratch. Could I just plug it in to a monitor motherboard and grab the other monitor components to make one?
Edit: This is my screen model if that helps
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@prowerpatroller nope, it's not that easy. You will need a driver board for your screen, as well as the main board and of course the power supply. Most of this will depend on what panel your Curtis TV is using and what has failed on it. Let us know what the symptoms on your TV are. It'll help if we know what does or does it not do.
Yes, it can be done. If your TV's main board, buffer boards and screen are still okay, you can just use the HDMI connections to connect it to your computer. If you do not have a working mainboard in your TV, you will need to substitute that for a driver board which is specific for the panel. For that we would need to know the exact panel model. Once you take your TV apart, there should be a sticker on the panel telling you the maker and the model. We would need to know what number to see if driver boards are available.
In general those are fun projects and can definitely help to keep your old TV out of the landfill. Let's work on it :-) Post some pictures of your boards with your question once you have the back cover removed. iFixitでの質問に画像を追加する方法
Update (08/12/26)
@prowerpatroller perfect. We now know that your panel is a CLAA133WA01 and all you would need is a kit like this one This is an example only and not an endorsement for the seller. To install it etc. it'll be very similar to the one shown here Universal LCD driver Technique - iFixit Repair Guide
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Toshiba Satellite C655D-S5200の画像
ガイド
汎用LCDドライバー技術
難易度:
中レベル
30 - 45 minutes
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much! By chance, do you happen to know a casing that would fit said screen and driver board?
さんによる
コメントを追加
回答を追加する
ProwerPatroller さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 47
過去 30 日: 47
今までの合計 47
