メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GMC SierraやVIA Vtruxとしても販売され、米国、カナダ、メキシコ、その他世界各国で利用可能です。
My reverse light are always on
My 05 chevy 1500 has a flatbed on it and was done on amature hour. The rear end wiring wasnt working so I decided to run new wiring from the fuse box using a fuse tap all the lights work but the problem is my reverse lights are always on. My question is does the switch for the reverse lights that i assum is either on the shifter or transmission lie between the battery and fuse box or the fusebox and the lights. If it's the latter then obviously I bypassed the switch but none of the other lights are like that so I don't see that being the case
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @loganloren71558
The backup switch is between the output side of the fuse and the BCM (Body Control Module) i.e. battery → B/UP 20A fuse → backup switch → BCM → backup lights.
Here's the backup lamp wiring diagram from the service manual.
When reverse gear is selected (either AT or MT) B/UP 20A fuse supplies voltage via the operated backup switch, to the BCM. The BCM then supplies the voltage to operate the backup lamps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chevylodge89 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 54
