メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to resolve "No Signal" issue?
Hi All,
I have an LG 46LD550. Whenever I power it on the display just shows the LG logo and says "No Signal". I have tried power cycling the TV - that didn't work. I reset the TV to factory settings - that didn't work.
I connected my laptop to the TV using an HDMI cable and it can see the TV no problem. I configured the Display settings so my laptop is the Primary and to Mirror the image to the TV. However, when I choose the HDMI port the cable's connected to it says "Connecting" for a few seconds and then returns to saying, "No Signal". I have tried all 4 HDMI ports on the TV and the result is the same with each.
I asked a friend about it and he said he's never had an issue getting any HDMI cable to send a video signal from a laptop to a TV. Still, I can't help but think there's some sort of incompatibility going on because I highly doubt all 4 of the HDMI ports on this TV are bad.
Does anyone have any suggestions as to how I can resolve this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @bodrey
Did you try using a different known working HDMI cable, you never mentioned whether you did or not?
Have you tried other signal input connection types beside HDMI e.g. RF, Component video, Composite video (AV) or even a different signal source e.g. dvd player or another computer (using HDMI) to see if there was a display shown on the screen?
This is just to prove that the problem is just TV HDMI input related and not other signal input types as well or whether the problem is with your laptop.
If you determine that it is only when using HDMI (regardless of HDMI cables used) and if it happens with any device connected to the TV using HDMI then most likely there's a problem on the main board in the TV as this is where the HDMI controller is located.
このアンサーは役に立ちましたか?
スコア 2
13 件のコメント:
Hi Jayeff,
No, I haven't tried a different HDMI cable. That said, the HDMI cable I'm using is brand new - I just bought it the other day. Now, it's a dollar store HDMI cable, and I don't know if they have a reputation for being DOA (Defective On Arrival).
I haven't tried any other inputs yet but this TV does have a couple USB inputs. So, I'm going to see if it recognizes a thumb drive and try to play a video with it. I also tried connecting a different laptop to it and the result was the same.
If USB works but HDMI doesn't then I suspect the HDMI controller is defective.
さんによる
@bodrey first tou need to determine if your TV works with any other input source. Other than your laptop.
さんによる
I'm going to test it using a thumb drive, see if it recognizes it and allows me to play a video file. I'll let you and Jayeff know if it works.
さんによる
@bodrey I would also test the HDMI on a different input. I have a feeling here.....:-)
さんによる
I have tested all 4 HDMI inputs on the TV. The result is the same on all.
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Bodrey さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 77
今までの合計 175
