My logo lightning is broken
My led on my logo is busted, how can i repair it because it wont work and it all adds up to a busted bulb, so how can i replace the led, are there any leds i can buy that can replace it, and what are they?
Hi!
Most likely soldered on the motherboard.
Replacing it will not be easy but is doable.
You can follow this guide to get the motherboard out: ロジクール Logitech G502 Hero マザーボードの交換
Not sure which LED is used, but most likely a SMD LED. The best thing to do, is to open it up and check what is inside there, so that you can buy a replacement one.
If possible, can you sent us the picture from the LED when taken? Thank you!
このアンサーは役に立ちましたか?
Thanks for the tip I’ll try to send a picture as soon as possible but probably tomorrow but yeah thanks for the tip!
Anytime! Thank you for that :)!
You can follow this to add pictures: iFixitでの質問に画像を追加する方法
Have a great day!
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 68
