L3 doesn't work
L3 doesn't pressing don't work
Does the analog stick still make the click when you press it?
If it does, cleaning the joystick with contact cleaner may fix it.
If not the button is likely busted and the joystick module will need to be replaced. This does require a good amount of soldering skills and tools, but is doable at home with some patience!
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 21
今までの合計 80
