メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
完全に再設計されたOptimaは、姉妹車であるHyundai i40とプラットフォームを共有し、韓国および中国市場ではKia K5として販売され、2010年のニューヨーク国際オートショーで世界初公開されました。
STEERING WHEEL Hard Turn
The Steering wheel is hard to turn left or right, idle or moving. I am not sure what is causing it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @jebenz
What year is the vehicle?
Asking as some have hydraulic power steering and others have electric power assisted steering
さんによる
Year of the vehicle is 2012.
I think it's a hydraulic because there's a reservoir for power steering fluid?
Not sure im not knowledgeable in cars.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @jebenz
Seems like your model is known as the Optima Hybrid, is this correct?
It is the only Optima that has electro-hydraulic power steering i.e. electric motor driven hydraulic power steering system rather than a car engine driven hydraulic power steering system. The other 2012 Optima models i.e. LX, EX & SX all have EPS.
About the only thing that I can suggest in this case, if the hydraulic fluid level is OK is to get the vehicle's OBDII port scanned with an appropriate scantool and check if any DTC codes (diagnostic trouble shooting codes) pertaining to the power steering have been logged.
If you're in the USA, then major auto parts retailers e.g. AutoZone, PepBoys, O'Reilley's etc, will do this for free apparently.
p.s. I edited my original answer as it wasn't relevant
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
I just checked and beside the coolant, it does say power steering fluid..
I opened the fuse box neer the engine and i did not see 80A..
Also, the car is automatic transmission..
Sadly the manual is missing, someone may have misplaced it.
I hope these info helps.
さんによる
Hi @jayeff,
I think it's not the hybrid..
In the car registration it showed 2.4 EX
It Also have tachometer not sure if this clears anything..
Yes the power steering fluid is at a good level.. not too low and not too high..
さんによる
@jebenz
Please verify the model year?
Best that I can find is that Optima models before 2011 have hydraulic power steering and models after 2011 (except the Hybrid) have EPS
I can't find anything regarding a gasoline engine only 2012 Optima model that has hydraulic power assisted steering.
The LX, EX, EX Turbo & SX models all have gasoline engines only and all have EPS (electric power steering)
The Hybrid model is the only one I found that has a gasoline engine and an electric motor and has electro hydraulic power steering i.e. electric motor driven hydraulic pump (not belt driven as in other makes of vehicles).
Check if there's an EPS warning light in the instrument panel in the dash. Models prior to 2011 didn't have one
What country are you in, maybe it's different for your location?
さんによる
Hi @jayeff,
This car was indeed 2012, it was one of the only 25 units (i believe) that was shipped out here to Philippines.
I also agree that this might be EHPS?
Upon ignition, i did not see a warning light showing EPS but im not sure if there might be a problem that's why it wont light or i may be wrong..
I was looking at the power steering fluid reservoir, the thick hose is going to a pump mounted on the engine with a pulley driven by the serpentine belt.. if this helps..
Should i have it checked first the obd2 so we can better identify or something?
さんによる
@jebenz
Since you've identified that there's a belt driven hydraulic pump I think that there won't be an EPS warning light in the instrument panel.
With the engine turned on, (gear in Park, handbrake on) check if the pulley on the hydraulic pump is turning driving the pump.
If the alternator belt or the hydraulic pump belt is not tensioned correctly (worn belt??) then the pump won't turn properly.
Be safety aware when you do this as there are moving parts. Keeps fingers, hair, clothing etc out of the way and simply observe.
If the pump pulley is not turning smoothly, switch off the engine first!! and then check if the alternator belt and hydraulic pump belts are tensioned OK.
If all appears OK check the hydraulic hose/hose connections for splits, leaks etc (although there's no fluid loss so it's probably OK)
If all appears to be OK it could be a pump problem or between the pump and the steering.
Here's a video that shows what a faulty pump could look like
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
J.E. Benz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 38
今までの合計 161
