See wonders when cutting
My Kobalt 6.5 I believe she’s isnkisaligned wonders sometime toward the end of cut I know. Blade is straight t
There's a few things it could be.
Hopefully that gives you some directions to find and solve your problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 86
1件のコメント
Hi @phileniabrooks
Have you tried replacing the blade with a new one. It may be that the teeth have worn down at an uneven rate causing the cut to go offline?
jayeff さんによる
