Check engine light on
PO171 PO174 error codes
The codes indicate a fuel too lean in Banks 1 & 2 problem.
This is usually either an airflow problem (too much air) or too little fuel getting to the engine.
Here's a video that shows how to check if the MAF (mass air flow) sensor is OK or not.
If it's a fuel problem it could be a clogged fuel filter or a fuel pump problem - low pressure
Hopefully a start to find out what's wrong.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 68
