メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Help diagnosing the fault.
Is this issue caused by the led strips or the led driver board?
I haven't been able to find other examples where the TV has two vertical dark sections as shown.
Thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @diegod
It could be faulty LEDs/LED connections in the LED backlight strip(s).
The TV has two LED strips which are mounted horizontally across the top and bottom edges of the screen i.e. it is an Edge lit screen and not as in other panels where the LED strips are mounted horizontally in rows across the back of the screen.
Can't find a free download online but here's a link where you can buy the service manual, which may make it easier to isolate further exactly where the problem is.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Diego dos Santos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 27
今までの合計 49
